Motorola Fire Ground System
mlynn
Northern Illinois
My fire department recently started using the Motorola Fire Ground System with our radio's (XTS 2500). We are trying to use the Fire Ground system along with MDC identifers. I am being told that since the Fire Ground system is a digital that the MDC is turned off when this is enabled. I would like to be able to use both options so that MDC identifers are transmitted all the time. Has anyone had any exprince with this Fire Ground system?
Thanks,
Mike
mlynn@countrysidefire.com
fineshot1
NJ USA (Republic of NJ)
We have little info from you on your fd communications system.
You need to reference from the RR database which communications system(a link would be nice).
If it is digital then there is no MDC signaling used. MDC is only possible to use on analog
communications.
Without more info I can not speculate any further.
Packetpeeker
Packetpeeker
Xts 2500
I'm Not sure about those radios, but no in digital mode you can"t use MDC signalling as the radio uses a digital identifier, if the radio operates in an analog mode for fireground you may be able to program or enable the MDC signalling system along with pre or post tone if you want it. I've worked on xts 3000 radios before but never set up anything in analog mode, also if radios are setup for p25 op. the analog feature may be disabled.
If i remember correctly we did set up mototrbo radios like that, digital for dispatch and analog with identifier for fireground.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Without knowing details of the system, other than what is on the brochure, the info might be passed with MDC codes. That would be adapting them to another use, and other MDC applications would not be able to process them.
Batwings21
Just set one up from scratch. When you choose a personality that has FG enabled it will not send mdc ID's. The long and short of it is the normal operating mode is this
radio keys up in astro and sends id and other data
radio switches to analog for voice transmission
radio then reverts to astro and sends more data and ID again
Firebuff66
CT
Thanks,
Mike
The radio will not do MDC on a fireground channel set up for the fireground software operation, all signaling goes out in digital mode.
