Motorola FV300 talkabout
jimbir
North tonawanda Ny
Can anyone point me to where I can find some tech help on these walkie talkies? I just cleaned out an estate and found a pair of them. One seems to work OK (all the buttons work). The other one fires up OK but, the screen is frozen showing channel 1 and "rx" next to it. None of the buttons respond. I've downloaded the manual but, it's no help with this problem.
Thanks for any help.
Jim B.
mformby
East Texas
Motorola radios
I would start by replacing all batteries with new ones. A voltage that is too low can cause all kinds of problems. Be sure both radios are on the same channel and same code (all display numbers match). Good luck.
Jim B.
jimbir
North tonawanda Ny
Thank you for the reply.
I've put new batteries in both units. My problem with one of the units is that none of the buttons respond when pushed thus, I can't change any of the settings with the menu button.
