Motorola HT1250 Speaker Mic Not Working
TangoEchoGolf
MO
This is the older HT1250 without the full keypad. With some speaker mics I can hear but not transmit, and others i can't do either. Does anyone know why it wouldnt work with speaker mics?
KG4INW
Midlothian, VA
Could be oxidation on the side contacts or the internal flex is failing. You can try gently cleaning the side contacts to see if it improves anything but a failing flex would need to be replaced.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
The above solution is most accurate, but also confirm that the speaker mics actually work by testing on another similar radio. If the screw that attaches the accessory connector will not fully seat, you would get similar issues as well. TT
