Motorola HT1250
codymw623
Ebensburg PA
Hi,
I was looking to see if someone could send me a Motorola HT 1250 code plug. I do not need the software. I was looking at buying a HT1250 but wanted to look at the code plug and mess with the programming software and see what this radio can do.
Thanks,
Cody
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Hi,
Thanks,
Cody
No need to ask for what you already have.
Since you have the software, look in the Samples folder down in program files under the CPS folder. There should be a sample codeplug for every different model of the entire Pro series.
codymw623
Ebensburg PA
For some reason i am not seeing that. All it is showing me is Motorola Pro CPS R06.12.05, it has a bunch of data files and pdf files.
SteveC0625
If you installed it correctly, it should be in:
C:\program files\motorola\professional series cps R06.12.05\samples
The samples have been included in every version update since I first got our subscription which was well before the version you have.
EDIT TO ADD: There should be two folders under Professional Series CPS. One is named Configure and the other is Named Samples.
