Motorola MaxTrac 16 Pin Accy question
davidgcet
yep, that will work for a fixed level. if the level is not enough, you will have to use pin 16 and adjust the volume control.
timkilbride
Linn Co Iowa
I use those $1 USB cards, they work pretty well with the RX audio of out Motorola radio. I just couldn't remember what pins I used for sure. Thanks for the reply.
Tim K.
timkilbride
Linn Co Iowa
I ended up using a male mono plug on the radio end. Pin 7 to ground and Pin 11 for audio. When I plug it into the computer, I get constant white noise, unless something is actually received. I then went to a male stereo plug. Pin 7 to ground and pin 11 to the left audio and I got the same results as before. I then moved pin 11 to the right audio and the white noise level went down, but was still present. I'm using a 25' shielded stereo extension cable to run from the radio to computer. Any ideas???
Tim K.
Batwings21
Banned
There is a jumper on the command board I believe for either discriminator audio out or filtered audio out. It is currently set for discriminator audio out on pin 11, you want to move it for filtered audio.
timkilbride
Linn Co Iowa
You were right. Thanks for the tip!
Tim K.
