Motorola maxtrac vs M100 Programing
I have a cable that will program gm300 and Maxtrac’s will it also program m100 the older ones? If not can I go to home depot purchase an rj45 extension and use another rj45 cable but in the extension change the wire configuration?
KG4INW
Midlothian, VA
They use the exact same cable so no need for a new one or any adapter.
KG4INW
Midlothian, VA
I assume you're talking about just the programming cable (RIB to mic jack, RJ45) in which case, yes, they are exactly the same. It doesn't matter if the radios are 5 pin or 16 pin when it comes to programming cables.
ramal121
Lots and lots of watts
Calif Whine Country
Yes, same exact cable. But of the three models you mentioned the software is different for each one.
Sent from my Nexus 7 using Tapatalk 2
