Motorola Minitor V
codymw623
Ebensburg PA
I have a general question about the Minitor V. I have a 2 channel, stored voice UHF pager. I have the pager set for Delayed N reset for 5 secs. When the pager activates it makes the squelch sound for 3-4 seconds or depending on how fast the dispatcher actually gives the dispatch. Is there a way to stop this squelch from happening. I have the squelch set for 3. It just gets annoying when your in public.
BlueDevil
WA
I know your feeling! I have wished for the same feature. The Motorola Minitor pagers do not have this ability. We are all just out of luck. Best alternative is to carry a radio with a 2-Tone feature such as an Icom F60V.
KD2DLL
Rotterdam, New York
Agreed. It can be a pain as sometimes our dispatch puts out the tones and waits nearly 10 seconds at times before giving is call information. I usually just turn the volume down a bit but that's really the best you can do.
I believe the reasoning behind the squelch opening completely after being activated is that in the event the signal is not very strong where you are at that moment, it has a much better chance of picking up something instead of missing it completely. Plus it does help catch your attention sometimes too.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
It is there to keep SV active in case the dispatcher drops carrier between the tones and the voice message. It is especially valuable in multiple channel systems with stacked paging tones. The longer (and more annoying) the squelch burst, the more you need it because you know that there is significant dropped carrier.
If you don't use the SV feature at all, the pager can be programmed to eliminate the open squelch.
We just went through this in another thread within the past week or so!
