Motorola MTR 2000 bricked, need help
StefanMiller
Hello everybody!
I had problems with wireline input on my UHF 40W MTR2000 with my old, working firmware.
So I flashed firmware version R03.04.003 but with wrong file „ocr30403.enc“ which is individual for every repeater. After flashing (100% success) I uploaded my old codeplug again.
Now I just have red LED lighting and repeater is out of work and message "MTR2000 RSS Station Feature Definition string not found. Please correct the feature definition file and repeat the station upgrade process.“ in RSS.
Could anybody help? Serial Number 512CAX0184, Station ID 000007C7B3F4, firmware Version R003.04.003 82R02676Y46.
I don´t have the older firmware to reflash.
Need the correct .enc file for flashing or advice how to change .enc-file.
Thank you so much! Any help welcome. Motorola Europe won´t help. Support finished.
Chris
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Firmware upgrades were machine specific as I think you’ve found out. You supplied Motorola with your serial number (backplane ID?) and they provided a firmware update for your machine.
Not sure there’s anyway around this except to have Motorola supply you with an update for your machine or you find a generic firmware that doesn’t care what your backplane ID is.
StefanMiller
Yes, Motorola in europe stopped support. I hope someone else could help me and send me firmware/.enc file or advice me to construct a working .enc file for my repeater.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Might want to buy a new controller or find someone who has an upgrade file for their backplane and have them upgrade your controller in their chassis.
StefanMiller
Do you think every used controller with another configuration (i.e. 100W station/900 Mhz station) will work in my repeater with my codeplug?
StefanMiller
I was able to unlock my repeater by making serial connection via Putty.
Then doing commands
dorss
hw_id_check_off
reset
Repeater boots and is working fine. After power reset it‘s locked again.
Any other idea?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Replace the controller or send it to someone who can upgrade it for you.
StefanMiller
Is anybody here in europe that has the last firmware update an could make an upgrade to my controller?
Or make a full flash dump without any deconstruction via Motorola Lab tool and serial programming cable?
thank you!
