Motorola MTX 8000 Programming Issues
danpoynter
I have programmed a Motorola MTX 8000 trunking etc. It recieves the talk groups and everything just fine but will not transmit. If your in any zone any channel and hit the PTT button it always defaults back to channel one in that zone... example If I am in ZONE A Channel 4 and hit the PTT button it changes the display on the top to "main" which is labeled for channel 1 of Zone A... what exactly am i doing wrong? thanks
dan
danpoynter
Re: Programming Issues
I am editing with mtsx lab software which I"m told is the same software it was programmed with in the begining... am i over looking something?
ILMRadioMan
The road to no where.
Well if I am not mistaken, the lab software allows you to change the programming for the PTT.
Could it have been programmed with a home mode?
Perhaps you should check that.
danpoynter
I am using Motorola RAdio Software R02.00.01 "MTSX LAB" Perhaps you can point me in that direction... I have been all over the software trying to figure that out. The only thing that I have been able to edit is the rotary switch and buttons on the side EXCEPT for the PTT button. Do i have to be in the SERVICE mode? Thanks
danpoynter
ref programming
seems i was using the wrong program... however did get the radio ptt button enabled but now when you key up just goes to straight solid tone.... What would the problem be on that end?
KB9LIQ
Banned
Central IL
My guess is you don't have the right info programmed into the radio. Do you have permission to be on the system? Does the system admin know about it?
ILMRadioMan
My guess is that MANY of the radio owners on this site arent authorized to listen in, and the system admins dont know it.
That being said, if we withheld info about programming radios (buttons of all things) because of that...this site would likely drastically slow down in traffic.
