Motorola MTX Help
steveng
On The Shores Of Beautiful Lake Erie
I found a Motorola MTX at a garage sale. The radio just says MTX on the front label. The Model # is H01UCF6DB5AN. Can someone tell me what the difference is between this radio and the MTS2000 or are they simmilar? They look identical. Thanks
FuelForFire
The Garden State
They look similar because they are both in the 'Jedi' series of radios. What you have is an MTX8000 Model II, it is capable of either Type I or Type I and Type II/IIi trunking depending on the model. You will have to read the radio to tell what type of trunking it is capable of but it is probably Type II or IIi
The main difference between this and the MTS2000 is that the MTX8000 is not flash upgradable and some will not all certain public safety frequencies (I believe over 866 Mhz) to be entered.
The MTX8000 did not come with an encyprtion option and was not intended to public safety use. Finally, the MTS2000 family had a top display model available while the MTX family did not.
Thats pretty much all I can think of off the top of my head.
Mike
jjflashcode
Mike
I do believe that the MTX family does have a top display model, a MTX2000(838), because I own One
Frank
FuelForFire
The Garden State
Frank
Right, I was thinking about the MTX8000, MTX9000, and MTX-LS. Those crazy Canadian radios did come with a top display. The continuous rotary is a cool feature too.
There are other MTX's out there with the top display that are hack jobs where a B5 or B7 codeplug has been dumped in and a B4 case has been added.
Mike
