Motorola Radios on Repeater Randomly bricked themselves
sammyg512
I've recently been working at an event, using Motorola DP4400 Series radios, connected to a few repeaters around the site, suddenly radios using Channel 1 stopped working and completely bricked themselves. None of the other channels seem to have been affected, connected to the same repeater, until they are changed to channel 1 Then they stop working, and wont turn back on.
It seems when the issue originally started, an unknown radio was used on Channel 1, after this unknown radio was used, that's when the issues started.
We also noticed, that before channel 1 failed, we had a gold notification star icon on the screen, after channel 1 failed the gold star icon disappeared, with no notifications in the list.
I've worked with Motorola Radios for years, and our hire company have over 30 years in the business, and neither of us have ever heard of this happening before.
More just for my own interest, but has anyone experienced this before or know what the cause may be?
K2NEC
39A
Radios dont just randomly inhibit themselves. It almost sounds like someone with a DP4600 or similar radio was sitting on channel 1 and disabling radio IDs. It's something that can be done by default in the radio front menu. Radios will also by default acknowledge and respond to the disable command.
sammyg512
That would make sense, as its only radios that were on channel 1, and radios that
Is it likely that someone has used a radio scanner to connect to the repeater, and been able to disable all radios on a channel using a scanner? Just our radio hire company, has said that they have disabled the inhibit function on individual radios. The radios are turning on, showing the motrbo logo, then the screen is going black and the radio is just turning off.
kb5udf
Louisiana
Scanner radios don't transmit, and so that can't "connect" to the repeater, another radio or anything else. In short, "a scanner" can't disable a two radio radio since the scanner can not transmit any commands or anything else.
Firebuff880
Boynton Beach, FL
If I were guessing. I would say that someone set up a Stun/Kill, and that the Radios being affected are not acknowledging the instruction, so it is still actively running in the infrastructure hosting it. Merrily disabling your fleet.
Since this is a DP subscriber, is it safe to assume you are in the EMEA region? Another off-the-wall guess is that Channel One is shared and is also in use on another nearby system, and that system is sending Stuns/Kills. If you were in NA, I would say check the FCC databases, but in the EMEA region, that's easier said than done, as I understand it.
sammyg512
Is there some political reason someone might do this?
Hopefully not, its a music festival for families. It just seems a little strange, radios are getting bricked only when transmitting on Channel 1, to the point they wont even turn back on.
That would make sense, when Channel 1 was working, we intermittently had an issue where radios would say channel busy, even if no one was transmitting. There are other events going on in the area, so if another event is using the same frequency, could it have been possible, they issued the kill/stun request if they were having the same issue?
K2NEC
39A
But they are acknowledging it because they are being disabled. Your explanation doesn't make any sense because it can't just run on the infrastructure like you say it can
If the radios are saying channel busy, your admit criteria needs to be changed. Any interference on the system will cause the radios to be denied. Horrible programming feature honestly.
You need to reprogram your radios to not follow inhibit commands and probably implement some security like RAS and Enhanced Privacy
sammyg512
Did you bid against another hire company that might be taking revenge? I had this happen to me at least 2 times.
ahaha, nope, the hire company used it the preferred supplier, and the only supplier used by the event management company! That's the first i've heard of that happening... Radio Wars!
Firebuff880
Boynton Beach, FL
No, the Stun/Kill can process in the subscriber, without the Ack making it back to the originating requestor (Control station/MNIS) application.
K2NEC
39A
I see what you are saying now. I meant that the subscriber is acknowledging the request
