Motorola radios with MDC-1200
WQOC472
Hello, I am looking into getting a new handheld radio, can someone tell me all the radios, NEW and Discontintued that havwe MDC-1200 as well a narrowband capibility? Thanks...
bezking
On the Road
Here are the ones I can think of offhand. You didn't mention if you needed SPECIFIC MDC features, or just ID Encode, so here are some starting points:
HT750 HT1250 HT1550
CP200
MTS2000
WQOC472
im looking for PTT ID, Ive got my eye on a HT1000 on ebay... Does the HT1000 have MDC PTT ID and Narrowband capable?
AYoung2600
Ohio
The HT1000 will do narrowband if the last 2 digits of the model number are DN. If they are anything other than that it won't do narrowband.
WQOC472
I work for a local TV Station, Our Studio and Broadcast Truck have motorola radios with narrowband frequencies and MDC-1200 PTT ID. I was looking into getting a handheld radio for myself and i needed to know which radios have narrowband as well as MDC-1200 Signaling.
coling223
Maine
Current models with MDC (all are NB capable)
CP Series with the exception of the CP100
PR series
HT series
EX series
Hope this helps.
squirrel911
Estill Springs/Decherd/Winchester/Franklin County
Just Asking
I looked at all these radios and since the FD i am on uses MDC 1200 to identify I want to buy my own radio both portable and mobile. Now in our engines when someone keys up on a radio it shows there ID. I would like for both the portable and mobile I buy to do this. Is there any radios out there that do it??
coling223
Maine
Most all currently offered radios from Kenwood, Motorola, Vertex and Icom have MDC capability, it's a pretty common form of signaling.
coling223
Maine
I can't vouch for much other than what I have personally seen which is limited, but obviously to decode a mdc Id the radio has to have a display. I know that the motorola pr400, cm300, ht1250, cdm1250 and 1550 all can display it, as well as the kenwood tk x180 series with the most recent firmware (both mobile and portable). With all of these you have to enable it in programming.
RKG
Boston, MA
We're having a problem here, because the Motorola MDC-1200 system has multiple functions (sending a user's ID on PTT is only one of them), so the phrase "doing MDC" isn't sufficiently defined.
If you want to be able to send a PTT-ID, all of the current XTS, XTL, HT1250/1500, CDM 1250/1500 radios will do that.
Decoding (and aliasing) radio MDC IDs was originally intended to be a console function. Later it was made available in some subscriber equipment, and is known as "PTT-ID" under the "Display" parameters. So far as I am aware, it is a firmware option upgrade in XTS/XTL equipment and not available in Waris equipment.
coling223
Maine
The Waris and commercial series WILL decode MDC ID's, however, you cannot assign aliases to them, they are just shown in the XXXX format.
