Motorola RDM2070D
sinor2018
I have a company issued radio RDM2070D and I'm trying to download the programming to the PC and upload to another. I need to select certain PL code to work with a certain number of radios in the store. I have the USB cable the software sees it. My problem is I keep getting this software doesn't support the radio region code. I've tried Business Radio CPS, RDM Series, MURS CPS, RDX Series CPS all say the same thing.
I do have CP110 Canada CPS that actually worked with A CP110 radio but it's asking for a password to connect. I am in need of the actual software made for the RDM radio or at least know the region code. I would manually program the radio expect a few have damaged PTT buttons due to people shoving pens in them. I tried to use an ear piece and hold the PTT button while powering on but no luck.
Any help would be appreciated.
Thank You,
BOB
ChrisE_STB
CA Database Admin
Bay Area
Hi Bob,
If I remember correctly, the WalMart RDM2070D radios have their own Firmware and use a special software.
If it is display model you can find the channel pl and dpl from the menu on those 1 watt radios. It should allow you to view each one that is assigned and change it if I recall on those firmware ones.
sinor2018
Yea the problem is the transmit button on some radios are broken so I can't access the menus. My next option is to get a clone cable to connect 2 docking stations together to clone the radios. I did get a cp110 radio to work with the software and found that it was region 4. I know the software exists just need to find it otherwise send it back to motorola for repair and that takes weeks just for a simple program modification.
