Motorola Smartzone work around?
minasha
NYC
I have a local motorola smartzone system that has many analog Tg's and only 2 P25 Tg's.
I programmed all 15 frequencies as Csq conventional channels and all the Tg's are working fine.
My question is: If I change all frequencies to p25 protocol instead of csq will I receive only p25 traffic?
Will it even work that way?
JSsignal16
From my experience no, because the talkgroup format is different. The G4/G5 relies solely on standard P25 talkgroup format for both P25 Conventional and trunked systems. I've tried everything I can think of and it won't pass any audio. The very last thing I tried was putting each channel in repeater mode which would normally pass audio from any talkgroup and nothing went through. There have been some people who have been able to get it to work, but I think that was solely due to how that particular system was configured.
minasha
NYC
I did get audio to pass on the conventional talk groups but not on the P25 Talk Groups Since there are only 2 P25 TG's if I got it to work it would be good because all the conventional traffic would be silent and I would get my 2 P25 TG"s making it a good system for me. However the P25 TG's simply won't come in
minasha
NYC
I heard p25 tg with this setting and it passes as pure static it won't decode unencrypted p25 this way.
Question:
Can I set each frequency as a wildcard talk group? in pps #4 group setting in each channel knob I want to enter ffff hex in P25T TGID column
will that work?
JSsignal16
You can try it. It may work for you depending on how the system is configured. All of the Smartzone systems I've tried doesn't work.
RFI-EMI-GUY
I am not a Unification expert, but from experience I can tell you this.
A Smartzone system with mixed mode analog and digital is not a "P25" system. It may have the Project 25 Common Air Interface for the digital channels but it operates under the analog 3600 control channel. The "CAI" feature in those systems is pretty much as useful as a screendoor on a submarine as far as interoperability with P25 standards. I would suggest, if you are trying this on a conventional basis and it fails. It could be those lone talk groups are encrypted. There is pretty much zero other reason for a mixed mode system having only a few digital TG's.
minasha
NYC
Hi
I am 100% sure the 2 p25 tg on this mixed system are not encrypted but even programmed as a p25 conventional the G5 doesnt bring it in
RFI-EMI-GUY
How do you know the TG's you want are unencrypted? There are about 10 TG;s that show either D or De. Out of 4 "D" talkgroups, I would bet the surveillance really are De and the radio techs maybe or maybe not.
This system is largely analog. The only reason to suffer P25 is for the encryption.
You will have to input all twenty channels in conventional to even have a chance.
k3sls
FM03qu North Myrtle Beach SC
Hi
Study up on the differences between Smartnet and P25 controllers. Smartnet does not do APCO P25, although it will allow digital voice over the analog frequency, and that's exactly what you're hearing, but not decoding. Check this Wiki for more on Smartnet/SmartZone capabilities.
minasha
NYC
Hi
The 2 surveillance channels are NOT encrypted. I listen to them every day with my Pro 668
They come in crystal clear.
i already loaded all 19 channels in the g5 as conventional p 25 it does not work.
You dont get anything this way it. Never picks up anything. if i change all 19 channels to
csq it will pickup all analog traffic but the p 25 channels will have digital noise not mickey mouse garble that comes with encrypted p25
Danny37
New York City
I really wish they added the support but I can understand why since smartzone is end of life and no longer supported. I honestly would buy one if they did but for now nothing around me is P25 trunking so it's no use for me at the moment. Like you, the Doitt system is really all I wanted to monitor.
