Motorola SP10 multi channel radio?
kv5e
T¹ ÆS Ø
These SP10 radios have been modded, (likely BearCom) to permit selection of 4 frequencies. This works by changing the DIP Switch connector remotely from the top of the radio.
The ones I have seen have MURS 4, MURS 5, and a couple of other LP channels on VHF.
Craig
com501
Remember the SP10 is only capable of 16 frequencies from the limited basic list anyway, all in the low VHF 151 or MURS band. The Batlabs page has the exact frequencies the radio is capable of.
Keep in mind the radio is only good for one more year anyway.
iamthe1one1
Springdale, OH
just to clarify
Anyone else who buys these..
The switch is connected via wire and soldered to the pins of the dip switch, if your capable of soldering, it would be a simple modification.
On the single channel its just the dip switch
mformby
East Texas
Motorola only made single channel SP10's. Bearcom (and possibly others) modified them (which voided the new warranty) with a 4 channel selector knob. Internally they ran a multi-conductor flat wire to the dip switch which changed the setting of the switch (electrically) when the channel selector was changed. They aren't bad little radios, just don't drop it because the plastic is brittle.
com501
It is also NOT NARROWBAND compliant as my post in this THREE YEAR OLD THREAD indicated, back in 2011.
com501
Why would you even bother with such ancient, cheap radios?
For only a few more bucks you can get any of a bunch of models that are much newer and much more capable.
I have about a hundred SP10s and 50s we are going to use for shotgun practice this weekend. That's all I use them for.
highcenter
Sacramento, CA
Scanning this morning and happened across a man and woman cursing up a storm on 464.55. Found this thread when looking up the frequency. Wish I would have recorded a bit. These two would make a sailor blush...
