Motorola spectra W3
Priority-One
Anonymous participant
Bronx, NY
I have little to no room where I live but i am interested in a base setup.
I've looked into the possibility of a W3 spectra for local ham and RX.
How can I find and know for sure on eBay I'm getting a unit compatible with a W3 control head?
I'm looking for 450-512mhz as most of my RX only is 470-490mhz
Can anyone point me in the right direction?
Priority-One
Bronx, NY
Forgot to add the picture, but this is exactly what I'm looking for.
radioman2001
Model number should be T or D04"S"KH9PW3AN "S"=450-482 "R"=438-470 if you are going to need P-25 the flash code must start with a "1" or "5" most other options in the radio can be modified with non M software. Also if you elect to buy an "S" radio you will have to hex edit the software for ham channels.
I see at least one radio on e-bay that fits you bill other than it's 110 watt.
Priority-One
Bronx, NY
I'm looking for the smaller 45 watt unit. The 110 watt would just take up to much room. The local repeater is on the GWB so less than 2 miles from me. I have a small astron unit that I think the smaller spectra will sit a top perfectly. I appreciate all the info. I'm looking for spend $125-$150.
N4KVE
PALM BEACH, FLORIDA
A Spectra, or Astro Spectra comes in 4 UHF splits. There is no 450-512 split version. Newer XTL's do that.
Range-1 403-433 MHz
Range-2 438-470 MHz
Range-3 450-482 MHz
Range-4 482-512 MHz
Priority-One
Bronx, NY
The farthest frequency would be 483.00625 (FDNY Citywide 2 RX only)
Also is this spectra capable if hosting a feed?
radioman2001
Using that FDNY freq will depend on the hardware in the radio UNLESS you buy a 482 mhz radio, and again if the firmware allows 6.25 channels some do some don't. Again you are trying to spread all over the UHF band, the radio may or may not work, you might be better off with an XTL.
Priority-One
Bronx, NY
That's what I'm thinking. I'm not really concerned about the P25 as there isn't much P25 in the clear in NYC. I have a VHF XTS5000R that I'm gonna be parting with soon and decide from there. I want something that will fit in my space I have. I'm looking at the XTL and XPR mobile.
