Motorola T5950 GMRS Radio
Thayne
I have been trying to program my kenwood handheld I use for work to talk to the cheesy yellow motorola GMRS radios they use at a large camp that I have to work at sometimes. The channel they use is 462.650, and my pro-92 shows the PL tone as 131.8. The motorola display says CH 19, with the "interference eliminator" code set at 97. The kenwood will not open the squelch on the Motorola with either the 131.8 or no tone; but the kenwood will open up when the motorola transmits only if no decode tone is set.
Any ideas or info sources??
(Legal sticklers don't worry I will set the transmit power low :) )
TX
Voyager
TX
Are you sure they aren't using CDCSS? IT will trigger a false reading of 131.8 or 136.5 on most decoders - especially at the end of a transmission. Listen to the signal. If it sounds like the tone is doing a 'wacka wacka' pulsing, that's CDCSS. (AKA DPL, DCG, DQC, Etc)
Joe M.
Voyager
A little research shows: "Codes 39–99 are additional digital codes added for superior interference protection."
Most likely, it is CDCSS.
Joe M.
Thayne
Thank you guys, it indeed sounds like that. I thought the pro-92 would decode it; are you saying it is or might be a different scheme than the DCS codes normally used. The Kenwood will do all the normal DCS codes.
Maybe I need to look at the output of the motorola with a service monitor.
Also I suppose they could even use different ones for transmit & receive??
Any thoughts?
scanfan03
Houston, Texas
To decode DPLs on the 92 press mode until it switches to DPL and make sure you are in manual mode. That will tell you the DPL or DCSS. If they are simplex, then they can't have two different recieve and transmit PLs or DPLs. It's not possible.
Thayne
I guess my brain wasn't working tonight, but I just programmed the kenwood with D465N and it works fine.
I assumed the PRO-92 would automatically detect PL or DPL. WRONG. Once I set it for DPL it came right up "D465"
At least Moto didn't use inverted DPL; I wonder if a PRO-92 would tell you that??
Thanks again, this will save me a lot of walking tomorrow!!
scanfan03
Houston, Texas
Yeah, you have to set the mode, then it will tell you the DPL or PL depending on what mode you have it in. Sometimes if the signal is a DPL it will show a PL even though it is wrong.
Voyager
I've got a news flash for ya - there really is no such thing as an inverted DPL. Every inverted code is equal to a standard code. For example, 023 inverted is the same as standard code 047, and inverted 047 is the same as standard code 023.
So, even if you found it was an 'inverted code', you can program a radio with the equivallent standard code and it would work fine.
Joe M.
Thayne
Keep those news flashes coming, I need all the help I can get.
I wonder why the "inverted" moniker came into being??
Voyager
It's a 'fix' for receivers that have one side injection vs opposite side injection. The difference between the two is that the signal is 'upside down' from the other. So, rather than programming the radio with the equivallent code, it is programmed with 'inverted' DPL on the same code. It overcomes the design differences between the two types of receivers.
Does that short answer explain it enough?
Joe M.
Thayne
Nope, I (still)don't get it. I assume you are not talking about injection as far as the local oscillator freqs where you end up with the IF's.
All of the DCS and CTCSS modulation only serves to open the squelch when it matches, right??
Anyway, I appreciate your efforts to explain it; I will try to read up on it.
Just getting that kenwood programmed so I could talk to those camp employees was what I needed, so I am happy.
Voyager
OK. Let's try it this way... when a CDCSS waveform is modulated, there are 1s and 0s - the 1s swing the carrier up and the 0z swing the carrier down in frequency. If, in the receiving process, the carrier is inverted, your signal is turned upside down and the 0s would represent a high swing and the 1s a low swing. This ends up making the digital waveform upside down from what it was. A 0=1, and a 1=0. Hence, inverting the code re-inverts the waveform and you end up with an upright waveform.
On voice or CTCSS, it doesn't matter if the signal is inverted or not since it's all sine waves. An upside down since wave sounds the same. But, with digital signals, reversing the 1s and 0s is a totally different waveform from what you started with.
This:
___I''''''I______I''''''I___
becomes this:
''''''I___I''''''''''''I___I''''''
If it's the injection that has you confused, all you really need to understand is that different injecton will make the signal a mirror image if itself - inverting it. Using an inverted code doubles the inversion and makes it 'look' right to the decoder. But, let's try this explaination: A receiver can either have high or low injection relative to the receiving frequency. If it's low injection, the difference of the carrier will be the same at the IF - highs are higher and lows are lower. BUT, if it uses high injection, the difference between the LO (Local Oscillator) and the carrier will be greater when the signal goes low, and less difference when the signals goes high. Remember, you are looking at the signal from the 'other wide' of the frequency. So, the IF shifts will be inverted from the true carrier shifts.
With the different injection, think of it as a bouncing ball, only one that is bouncing digitally - either high or low at any given point. If you watch the ball from the bottom, the higher it is, the farther the distance from you. All well and good since close=0 and far=1. But, if you watch the ball from above, the higher it is, the closer it is to you, and close=0 and far=1 digitally. So, on peaks of height, you are seeing the ball closer (a '0') when in fact it is in reality a '1'.
Did either of those examples help at all?
Joe M.
Thayne
Oh yeah. I did not get the totally different way the digital affects the modulation as opposed to a sub-audible tone being only being imposed on the carrier.
I still remember when I was an apprentice, this old guy chewed me out for assuming this unit I was working on was off and would stay off. After I got knocked on my ass and he picked me up; he said "Assume" really means "Makes an ASS of U (and) ME "
TX again
Edfutbol
T5950
Does anyone know the PL code for # 1 Interference Eliminator code for T5950? Would appreciate the help.
Thanks!
