Yep Private Call is available on most Motorola TRS's ... some are set up to go conventional and a few trunk,.. but do it with a special TG system that does not show up on most of the Radio Shack Trunking Scanners. Not sure if the PRO-96 will do PC/IC or not,.. the Unidens as listed above will. Remeber don't confuse talk around with private call,... on Motorola you can do both,... talk around goes conventional and is usually not sent through the repeater, where as pc's do go through the repeater. Have seen both kinds of pc in use,.. the conventional,.. which is a poor choice as was stated in another post ties up the repeaters,....and the specail tg, which is much more effecient. Does anyone know if the Unidens track the PC vias conventional method as well as the special TG method? Also a quick query,... When phone patch is active,... will the new trunkers track these?
