Motorola xpr3300e zones
Chesky
How many zones can the xpr3300e have in total? Trying to maximize what I can.
K2NEC
NA
Are you sure because I was able to have up to five zones? I was wondering, maybe if I could have more like the XPR 7550
How do you figure the radio has the ability to cycle between 5 different zones? If you need more than 16 channels get an XPR7350, if you need more than 32 channels get an XPR7550
K2NEC
NA
I believe I read somewhere the latest firmware supporting it, but otherwise the radio only supports 16
Chesky
Because I put 5 zones and it works
emacs
New York
XPR 3300e supports up to 64 channels. A few months back I had to open a case with Motorola as the radio firmware and CPS supported multiple zones, but the CPS did not allow you to program any buttons to toggle between zones. After elevating the case to the engineering department I was given a modified version of the CPS, and now the current version available to download from Partner Hub should support multiple zones and the ability to cycle through them. Voice announcements are obviously very helpful for keeping track of where you are considering the lack of a display.
