Motorola xpr4550 code plug request
troyken
Would someone be able to provide a suitable code plug for an XPR 4550 radio? Model is AAM27TRH9LA1AN 450-520 mhz.
We are testing a newly assigned ( frequency coordinator) Fire Dept. frequency and the vehicle radio I want to use as a test radio is code plug password locked. We own it and many others and I need to input new freq. and set power level to comply with ERP requirements.
Thank You Very much in advance.
FFPM571
Nashvillle
overwriting it with a same model codeplug will not work You can try a recovery but it will wipe the whole radio and set it back to factory
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
You can't write another radio's codeplug into a radio with a different serial number.
troyken
Long story but our uhf mobile frequency is now new license limited to 25 watts. Fire house uhf base to a future repeater now-7 watts erp with mandatory use of a yagi antenna. Our current radios are all set on high power- 40 watts ,lower power setting not programmed or selectable. I have had no problems with CDM radios. It is the XPR- 4550 in a utility vehicle, that is the issue, hence the need to access that specific radio program. We own all radios and they are all the 40 watt high power models as far as I can tell.
This is all volunteer by the way.....
The obvious use of the original radio guy is not a desirable option in this case.
If there is another way to gain access to the radio, I'm open to it.
