Motorola XTS 2500 "secure"
lightningx54
Feed Provider/Amateur Radio Operator
I have a XTS 2500 Model 3 FPP VHF and I'm using it in mixed mode RX because I two channels I use, one analog and one digital same frequency, just simplex. When I have the radio in analog TX though it key quickly 5 times and flashes "secure" on the screen. It'll do that every couple minutes. What would cause that?
Project25_MASTR
Millennial Graying OBT Guy
Texas
The Secure knob in the secure position would be my first thought. Might also check and make sure it's in analog transmit and not digital for that mode.
lightningx54
What secure knob? The RX is Mixed mode and the TX is set for analog in FPP. There has to be a setting in CPS that I'm missing.
TLF82
Texas
Check the secure settings under the conventional personality tab.
Why are you pressing the PTT 5 times in a row quickly?
lightningx54
You are miss reading the original post. The radio its self is keying 5 times then flashing "secure".
TLF82
Texas
it sounds like the radio may have some issues.
What version of firmware is on it currently?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
An analog mode set for Mixed Mode Receive with encryption enabled will transmit in encrypted digital.
Check your Conventional Personality's Secure tab. Secure/Clear strapping should be set to Clear if you have no intention of using Secure on your analog channel.
N4DES
Retired 0598 Czar ÆS Ø
South FL
If it was digital P25 that it was occuring I was initially thinking that DVRS is enabled and it is looking for its mate. But in analog?? Hmmm.....
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Yes, in analog.
Set your Rx Voice/Signal Type to Mixed Mode, Tx Voice/Signal Type to Analog and Secure Voice/Signal Type to Astro.
Turning Secure on will cause your analog channel to transmit in Secure Astro mode.
lightningx54
Yes, in analog.
I will check that out. I need to find my CD and reinstall CPS on this machine first though. Thanks.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I wondered as well but I'd be more worried of a BN posing as an AN rather than an AN posing as a BN although you never know what some people might do.
TLF82
Texas
This is true! Unless one decides to try and drop some BN firmware into an AN radio... Hello expensive brick!
lightningx54
With that firmware and DSP, it's most likely a 4meg AN.
Does the radio model number end in AN or BN?
Model is AN and says 8meg
com501
It cannot be an AN with an 8meg board. Someone has done some finger plucking. I have had ONE exception to this rule, and it came from the Depot. They subbed a BN board into an AN frame on a flat rate repair because they were out of AN boards, then proceeded to force the AN programming into it which caused ALL kinds of issues. I sent it back and made the Depot replace the housing with the correct BN housing. (and a blank load so it could be programmed correctly)
