motorola xts 3000 help
N4DES
Retired 0598 Czar ÆS Ø
South FL
Your best bet is to sell the radio and buy a scanner. Programming an unauthorized radio can cause havoc on a TRS and in time the radio will be bricked and your great deal will be worthless.
There are no actual "manuals" to instruct you how to program it and and unless the system owner "allows" your radio to be programmed onto the system you should sell it and buy a scanner.
There are a ton of threads on this site with the same exact recommendation, you should of searched first.
Mark KS4VT
813A System Administrator
mancow
N.E. Kansas
Go to batlabs.com and check out the programming primer.
If you want to work with conventional non trunking channels only then no problem. There's nothing illegal, immoral, or wrong about that. Just don't transmit where you aren't supposed to.
The XTS uses the same CPS as the astro saber. You will have to buy that from Motorola after establishing a Motorola On Line (MOL) account. Then you will have to sign the license agreement and do the whole dance for them. Once you are allowed to purchase it you get 3 years of upgrades with your subscription. The cost is around $300-$400.
You can find good aftermarket ribless programming cables on ebay for around $40. I have one and it's great.
As for trunking, forget it. Unless you are authorized to be on the system you will risk having the radio remotely disabled by the system admin. Then you are stuck with a doorknob that looks like a radio. You would need the system key to even get that far anway, as the software won't allow you to edit the trunking fields without one in the proper directory.
