Motorola xts 5000r program question
bobbuff
brockton ma
I am in the process of programming my xts 5000r. In the past I was able to use the 3 position toggle switch on my MT2000 and xts 3000 radios to use Position A - scan, Position B - Non-scan and Position C - scan list prgm. For some reason I can not find "non-scan" for the lack of terminology in the drop down. Is this something I'm just missing, need to add to the drop down, if so how is this done or is this a feature not available anymore. Thanks for any help in advance.
Tobydog
Try the concentric switch under the channel selector switch to turn scan on and off. Not sure it was in CPS just setting the concentric switch is all I could accomplish
bobbuff
brockton ma
GTR8000
NY/NJ Database Guy
BEE00
Auto-scan overrides any button/switch assignment. If you want to be able to turn scan on/off manually, you must disable auto-scan.
K2NEC
NA
Then it's still set as a button or a soft key. If you don't want to scan then make sure that personality doesn't have auto scan and take it out of the scan list. Or delete all your scan lists and take scan out of your menu and side buttons.
bobbuff
brockton ma
maybe I didn't post this correctly, I want the zones to scan will listening, but I want to be able to disable the scan and go to one channel using the rotary knob as a manual select to go to a specific channel and just listen to that channel only. Does that make more sense ?
