Motorola XTS5000 and XTS5000R 700/800MHz
Peoria, IL
Hello I wanted to know what the difference is between these radios I have the XTS5000.But what is the different about the XTS5000R.
Thank you
Anthony Lee
MTS2000des
5B2_BEE00 Czar
Thank you
Anthony Lee
The "R" version is submersible (if it's properly serviced or came from the factory) in fresh water, note the spec sheet confirms IPX7 submersion "for ruggedized models only".
The radio internals are identical between the "R" and non "R", the ruggedized models have a pressure vent port on the back and are leak tested at the factory. And of course the "R" on the front cover label...:D
http://www.motorolasolutions.com/we...ments/Static Files/R3-4-2009F_XTS5000_new.pdf
