XPR Mototrbo adapter question
GregOH
New Phila, OH
I'd like to know if the 3.5mm jack of the adapter at the link below that converts the multi pin connection like my xpr3300e to the two pin cp200 style connection will output audio or is both the 3.5mm and 2.5mm needed? Plugging headphones with a 3.5mm into it and hear audio is what I'm wanting to do if it'll work.
K2NEC
NA
The CP200(d) uses a 3.5mm Mono port, you can use headphones but expect to hear out of one not the other
16b
Central Ohio
To use stereo headphones, you can get a mono to stereo adapter like this: https://a.co/d/cT5EPm4 or just live with the audio coming out of only one earpiece like K2NEC said. Having an adapter sticking out of another adapter would probably be a little bulky though. A mono earpiece is another option. I remember using a mono earpiece on my GP300 (same pinout) many years ago.
The 2.5mm jack is used for the microphone audio (if memory serves) so no need to worry about that.
GregOH
New Phila, OH
I'm ok with an earpiece. I guess I should have asked if I use an earpiece with the 3.5mm jack plugged into this adapter, will I hear the audio and be able to use the ptt button on the radio and transmit?
At the moment, I'm using a mic and have an earpiece with acoustic tube plugged into the 3.5mm jack on the mic. I'd like to do away with the mic and only use the radio and an earpiece. I figured the 3.5 is for speaker audio and the 2.5 is to transmit but I wasn't sure and I no longer have a cp200 to test it.
K2NEC
NA
As long as you have the radio set to "Mic follow PTT" in General settings, you will be fine
