MOTOTRBO - Multiple Call Groups
brad82
Hi All,
We upgraded all our old GP320s to the new MOTOTRBO DP3600s the other month, and I've been wondering if we can set a call group system up
There are 2 groups using the radios, IT and Maintenance. We have a DM4550 as a base station. What I would like to do is make it possible for the base station to broadcast to certain groups, however still receive communication from both groups when not sending a message
Is this possible?
brad82
-- More Detail --
Sorry I can't work out how to edit a original post. Forgive me!
My question is rather vague, allow me to explain.
We have 6 MOTOTRBO DP3600s, distributed in 2 groups. IT contains 4 radios, and Maintenance has 2. We then have an XPR4550 at reception.
Maintenance is a busy group compared to IT, and we want to try divide the two groups. IT and Maintenance do not need to communicate between each other, however I would like to set it up so that reception can place calls to each group.
Obviously I could run each group on separate frequency, however I would like reception to still be able to receive communication from both groups.
Basically: Reception can transmit/receive to either group A or group B, and group A/B cannot communicate between each other.
I would prefer to be able to complete this without purchasing any more equipment, however if we absolutely have to thats what I will have to do!
Cheers
Dorf411
Western S. Dak
Are you operating in digital or analog? If in digital you can easily do that by setting up separate call groups for IT and Maint. The mobile at the desk could have both channels and talk to both at the same time by using an all call or to just one or the other. This can all be done on a single frequency or a single repeater using the digital ID's of the radio. Your Motorola vendor should be able to program this for you.
