Mototrbo Radio Management- MDC-1200 Settings
zsauve
Oak Creek, WI
I am in the process of trying to get all of our radios set up for Radio Management-Configuration Mode to allow over the air programming and management of my radio fleet. We use several analog repeaters in the event of trunked system failure and use MDC-1200 to identify radios when in analog mode. Is there a way to make every radio have its own individual MDC-1200 ID? When I go to change the ID in the set/configuration, it applies the same ID to every radio. Do I need to create an individual set per radio ID in order to accomplish this?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You should not have to change it there. You would change it in the radio view that has all of the unique radio information. It is a unique piece of info like serial, radio I'd, etc and displays as such. TT
hakwye8518
Town of Islip, NY
MDC id isn't shown on the radio view just digital radio id and ip address. I have the same issue. need to figure out how to keep the mdcids differant for every radio instead of being changed to the mdc id thats in the configuration
Firebuff880
Boynton Beach, FL
I don't have a Radio Manager Client open right now.
But if you go to the Radio View, and right click in the Column headings a List box will open and you will find a number of data elements that are normally hidden (un-checked). You can customize the view by checking or un-checking various column headers in this dialog and then clicking on the X in the upper right to close it..
One of the hidden columns is labeled 5-tone. This MAY be what you are looking for.
Firebuff880
Boynton Beach, FL
@zsauve
I say it looks like a bug / oversight on some ones part. As that data element appears like it should be on the Radio View and not as part of a single unique set. Have you opened a case on this ?
Motorola Customer Support 800-927-2744
