mototrbo repeater Ethernet port not working
jen02
Our current repeater Ethernet port is not working because it was affected by some lightning surge but the two way communication is still OK. I just like to ask if there is other way to still connect in an IP site without using Ethernet port. By the way the disabled led indicator of the repeater at the front panel is color red.
Thanks.
G6GFA
UK
There is no other way to ip connect the repeater. I had a similar problem with lightning damage on a customer's unit a few months back. The Ethernet interface is actually on the LED PCB so it sounds like that's got fried. The replacement PCB was about £70 GBP as far as I remember and is very easy to change.
jen02
Where did you buy the PCB? Or what is the part number?
G6GFA
UK
I work for a Motorola dealer here in the UK so we bought it direct from Motorola. From memory there were several different part numbers depending on the exact model. I could look them up for a UK spec repeater, however i suspect yours isn't a UK version in which case it may not be accurate.
I'd be 99% sure it will fix the problem, I had the exact same thing happen (apart from the LEDs). Lightning strike half a mile down the road, looked like it induced a large voltage into the landline which then hit the ungrounded router. From there it went to ground via the Ethernet cable, taking out the router port and the repeaters network interface.
