Mototrbo SLR repeater and XPR 8400
LowderK
LEO / Paramedic
Western Oklahoma
Ok here is question I have .. we have two repeaters at the same site, one is a SLR 5700 VHF and the other is a XPR 8400 UHF is it possible to like the two together using a cat 5 cable from the Ethernet ports both repeaters are in the same rack mount. what we are trying to do is make the system cross band so no matter what radio you have ( UHF or VHF) all will hear.... there is no internet at the site to do the standard IPSC... thanks for any help
Flyham
Purplexed
A cable like this can do that, however in the digital world it can be STRONGLY DISCOURAGED as double vocoding presents some less than desirable audio characteristics to the end users.
Firebuff880
Boynton Beach, FL
Yes, you do
How else are the sites supposed to connect to each other?
IPSC
No you really don't in this case -- The SLR-5700 should be configured as Site 1 and XPR-8400 as Site 2 with Slot 1 being Wide area and the two linked via a switch. NOW your VHF and your UHF subscribers will be on a "common" Slot / System. I have never built one like this but I have talked with people who have and the Internet connection is only needed if you want remote access / support or have a third non-co-located site, .
Good luck with your project ---
n1das
Nashua, NH
It looks like this is an analog link between two radios or repeaters. I agree that double vocoding sounds like "expletive". This is not what the OP wants to do. With IPSC, the audio never exists as analog between repeaters.
I assume "linked via a switch" refers to a network switch in which the CAT5 Ethernet cable from each repeater would be plugged into the switch. IP connectivity would be provided by the switch, even if the local area network you created with the switch doesn't go off-site. You essentially are using IPSC when linking 2 repeaters at the same site with a switch and don't have an internet connection.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You can use a switch or cross over cable, but it will work fine. Both bands will be linked. Up to you to decide if you want one slot or both slots linked. Make sure your slots and talkgroups are same in both band radios. TT
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I'm involved with a private Cap+ system where we have 2 physical sites, that have both VHF and UHF repeaters.
It uses 4 of your available 16 sites to do it, but it works well.
LowderK
LEO / Paramedic
Western Oklahoma
Ok both repeaters in same building and only running digital ..... can they be linked without internet
LowderK
LEO / Paramedic
Western Oklahoma
This is a personal project in the commercial bands.... but some of us have vhf radios and some have uhf and would like to be able to all talk.... the SLR repeater has two ports and the XPR only has one
crazyboy
NJ
Run a crossover cable from Ethernet 1 on SLR to Ethernet on XPR. Reprogram the two repeaters and boom. About as easy as it gets.
gman1971
Good thread. Thank you.
Another question, could you make one of the repeaters work in DCDM (single frequency) while the other as a regular frequency pair repeater?
Thanks.
