Mounting advise
dnlbrrg
Grand Rapids, MI
I need help mounting my CB to my car.
Basically, I just don't want to drill holes in my car to install the bracket. Are there any other ways of securing the base?
hockeyshrink
1. Use existing screws, like under the glove compartment.
2. Use heavy duty double sided gorilla tape. May or may not work depending on size and weight of the radio.
3. Oh just drill the damn hole!!!
:cool:
LtDoc
Oklahoma
If you want a really stable mount it amounts to drilling holes or using existing holes. Depending on your imagination, those 'holes' don't have to be in obvious places. Mounting brackets/plates/thingys can be of lots of shapes and positions.
For not so stable mounting, the options go through the roof. Glue the thing to something, use a cup-holder type mount, sand bag it, velcro, who knows what else?
A lot of it is convenience. Where can you put the thing that means you will loose some feature of your car that you don't necessarily need/want all that much? Is there a panel that could be replaced if you decide to remove the radio? One that doesn't cost an arm-n-leg?
Lots of options. You have to decide...
- 'Doc
