Mounting antenna on existing pole?
BLPen163
Wesley Chapel Florida
Would mounting an antenna to the pole in the picture be a good idea or will it get interference from the pole light ?
Thank you
AK9R
Staff member
Super Moderator
Central Indiana
What bands? What antenna? Will it be above the light?
geartow
I had a uhf/vhf antenna on a pole 5 ft above a similar light, it did have very mild noise from it I just flipped the breaker and turned it off when I operated.
BLPen163
Pole is mine. Will mount on the backside of pole away from the conduit for the light and extend above the top of the pole as far as possible. 2m 70cm Fong style antenna. Thank you
