Mountpoint in Use - Feed Keeps Disconnecting and Reconnecting
Twister_2
Dauphin County, PA
My feed keeps going on and offline. According to Radio feed, when it goes off, it's because the mount point is in use. I don't have any other copies of this software open nor am I logged in on any other computers. A previous thread suggests tracking your IP to see what's going on but this seems like a broadcastify issue?
flythunderbird
Grid square EM99fh
This may be stating the obvious and you may have already done it; if so, I apologize in advance. Have you tried rebooting both the modem and the router?
Twister_2
Dauphin County, PA
Yup. It's acting like there's another instance of the program open with my login credentials. I will try changing my password and seeing if that fixes it.
Twister_2
Dauphin County, PA
AAAAND now I'm getting the timeout error. I'm no IT expert but this seems to be on RR's side.
ProScan
Software Provider
Ontario, Calif.
The dropped connections could be caused by your computer, NIC card, cables, router, ISP, etc.
I suggest using a tool called PingPlotter to isolate where the problem is. I've seen several cases here using PingPlotter and finding the problem.
Here are a couple of links that may be helpful.
https://forums.radioreference.com/threads/feed-keeps-dropping-out.385850/#post-3099449
https://forums.radioreference.com/threads/connection-issues.367289/#post-2897512
{edit} Insure you are not running AVG Anti Virus software as that is known to interrupt TCP traffic.
eaf1956
Evansville, IN
I had this issue with my feed after MS did an update and crashed my feed computer. After a System Restore the feed would connect and disconnect over and over. I did a reboot and when Proscan started I got a warning about parts of Proscan being blocked. I clicked ALLOW and the problem went away.
Sent from my SM-N960U using Tapatalk
