Hi I am in the NY district and will be soon moving to Florida, are there any advantages od disatvantages of changing my call sign to the new district or keeping it the same? Also how would one go about doing so, including updating address with fcc? Any suggestions would be appreciated. Thanks!
ps: not a vanity call sign if it matters
Changing your call is as easy as using the
FCC Universal Licensing System (ULS): ULS Home. Simply login get assigned a FRN (FCC Registration Number), and you're off to the races...
Under the new rules, as long as the FCC has a ~contact address~ that is valid, you can keep and take your call with you. I myself know several snow-birds, they keep the call of the district they consider "home." The truckers I make contacts with, and the RVers, who drive all over the country, keep their calls the same no matter where they are based.
While having a number in your call, that would for the most part, give people a heads up as to where you most likely are, in every DX contact I've made, and every contest I've worked, one of the basic bits of information exchanged, is where one is operating from, not where one lives!
Does your call carry a "good weight" for CW? Does it make for good "homemade phonetics"? Is it a call that you earned with your Elmer? Does your call mark a special time in your life?
Bottom line is this, how do ~you~ feel about your call? If you like it keep it! If not...
