Moving objects?
noobiest
watr ct
I was wondering if objects can be moved to different lists? I have a Pro-106 and Win500. The archives and manual didn't say anything, unless I missed it. My tags are all written out and I was hoping to drag them around on the software.
pathalogical
Toronto, Canada
In your CONV or TSYS Objects tab, highlight the object you want to move, then, on the right hand side of the screen you'll see Details for objects ID xxxx. Simply check off the list want to move it from and check off the list you want it moved to. As you may know you can have the object in multiple lists, just check off where you want it. You'll see the scan list number change in the Scan List Map column of the highlighted object.
noobiest
watr ct
Thanks a lot, time to clean things up and add more stuff !
Very easy thanks and thanks to Don S. too
