Moving Systems?
hiegtx
Dallas, TX
#4
That would be the 536. I am unable to find a way to do this either with Sentinel or with ARC536PRO.
If you are referring to copying an existing system from one of your Favorites lists to one or more additional ones, that's easily done in Sentinel. Simply <right><click> on the system you wist to copy, choose Append from the pop-up menu, then choose the Favorites list to send it to from the list.
Hilliard, OH
#5
AH! And can I do that also with an empty list? I will try! :)
EDIT: Yes that did it. Thanks! :)
