The FD I work for is going to be going over to MPSCS shortly, along with the rest of the county. I have approached our chief about purchasing a base scanner for each of our stations, so we can monitor more than the duty radios are going to be programmed for. (We don't need or want to monitor half the state with the duty radios.)
I have been rather happy with my personally PSR-500, that I purchased at Hamvention two months ago, and would like to go with the PSR-600. I have also had good luck with various Uniden scanners I have owned and used over the years. I am wanting to find the best performing scanner, with an ease of use for the non "radio geek."
I will be programming these radios, and rarely modifying the programming. They will be left with instructions for restoring the programming, should I not be available, so the overall programming is not the primary concern.
Who has used both the BCD996T (not the BCD996XT) and the PSR-600? Who has used them on P25 systems? Which performs better? Which is easier to use? Is there a definite case where ease of use was significant enough to warrant a possible slight decrease in performance?
Thanks in advance.
Thanks in advance.
