mpscs programming question
313RADIO
my pro-106 i have setup each bank for a certain agency on the mpscs. that way i can tune into a certian city just by hitting a button... I have control frequencies for Detroit and macomb simulcast programmed into the same system so it most of the time automatically pickups up the strongest signal depending on where i am at (Am i right?)
anyway is there a way to manually override what control channel is being tuned in? or perhaps is there a better way to setup my programming?
iMONITOR
Silent Key
S.E. Michigan
You should configure a separate TSYS for Detroit, and Macomb. Also make sure you have your Multi-Site settings correct, and read the differences between STAT & ROAM.
313RADIO
ok... but is there a way the 2 separate TSYS can share the same list of talk groups? to save memory?
macari77
Downriver, MI
I have the same problem with the Downriver mutual aid (which is the strongest by my house) and the Wester Wayne County mutual aid. I can only get Downriver.
I too have a memory issue
