devicelab
Whacker Extraordinaire
I used Caddock MP930 resistors in series (2450 ohms) across the connectors of the Mr Baluns 49:1 EFHW balun. I ran a sweep on it at work:
Yep I've been reading up on those but the MrBaluns 49:1 was 1/5th the cost the MYANT kit and 1/2 the cost of the BalunDesigns 49:1 -- although it technically supports up to 1KW output. I'll never go that high however.
prcguy, i purchased a 49:1 TennTennas transformer and saw something interesting. (I'll post its sweep later tonight.)
The primary connect point is super sensitive. If I simply place the plastic box on top of the VNA it goes nuts. If I put it anywhere near metal it goes nuts. If I touch the nut it goes nuts. I didn't remotely have this behavior with the MrBaluns model. To get the sweep I had to place it a good 2ft away from the VNA cart. Is this normal?
PS. The chart looks similar but this transformer favors the middle bands.
When it's written 49:1 I assume the 49 side are the primary, or it would be written 1:49? But anyhow one side are high impedance and are then super sensitive to any nearby metal. That's why you have plastic or ceramic insulators on the end of antennas, that are high ohm, to isolate even to a tree branch.I didn't remotely have this behavior with the MrBaluns model.
Thanks Ubbe. Here's the chart for the TennTennas unit. I'll take an inside look later today. I'm curious to compare the designs between the two.
