I am trying to connect Uniden's MRN-GPSK gps to my 436hp, with a db9 serial cable and the BWZG1844001 cable. The wire color code diagram off the MRN-GPSK gps lists:
Red-External Speaker (A)
Black -External Speaker (B)
Orange - Blank
Bare- Ground/Shield
Yellow- NMEA In (A)
Green- NMEA In (B)
White- NMEA Out (A)
Brown NMEA Out (B)
Which color should be wired to the serial cable, I am assuming on the Db9 it will be pin 5 for ground and pin 2 and 3,maybe pin 8 (correct me if I am wrong) but which wire from the GPS go to which pin on the serial cable? I have search the RR forum and cannot find this answer. I have completed the USB power supply to the GPS. Thank you in advance.
Orange - Blank
Bare- Ground/Shield
Yellow- NMEA In (A)
Green- NMEA In (B)
White- NMEA Out (A)
Brown NMEA Out (B)
