Yes, I'm told it is (was? has it changed?) a simple 1200 baud ASCII signal that sends out nothing more than a series of geographic coordinates. There are a great many packages out there that could potentially decode this. The Utility Monitoring Central link on our Utility wiki will give you a good selection, if you're interested. Likely as not, since it's so low-speed, that a discriminator tap would not be needed 73 Mike
