mt1000 send/recieve
#1
Hi everyone, I was wondering if I can get some help. I had taken my mt1000 16 channel vhf radio down to the local repair shop and the guy has had it 2 weeks. Well anyway he said he cant figure out how to boost the signal strength or power to the transmit. My problem is I can not talk to dispatch, I can hear fine and I can talk to another radio 10 feet away. Any help would be appreciated. Thanks
Central Arkansas
#2
Take it to another Tech, the power is set via software, choice is low or high. When I had mine programed the Tech asked me how far I would be operating from the repeater and said he would set it to high for me.
Grog
Banned
West of Charlotte NC
#4
Maybe the finals are fried, but those are about the ruggedest /\/\ ever built, so I'd go with programmer error first.
Grog
Banned
#6
redzo6 said:
Thanks, how would you tell if the finals are fried?
I have no bloddy idea, but I real radio tech should be able to test the radio and find out. That is a tech with the needed tools and experience, which is not as easy to find anymore. I would say a watt meter reading would be helpful, if it's only putting out a fraction of a watt, well that would be a clue. Once again I mention a tech with the tools and experience, as the MT1000 can't just use a simple antenna jack mounted adapter for that, but not everyone would know.
#7
Thanks, The man at the shop is in his 50's and seems knowlegdable, but he told me a couple days ago that this other guy was going to be there and new more about "these motorola's". I guess i should just pick it up and take it somewhere else. 2 weeks seems a long time for me.
#8
Well I went to pick it up, and the man had fixed it. The antenna base was not making a connection to the radio. So bad antenna. I am good now. Thanks everyone
