MT2000 Controller Boards...
62Truck
Ordinary Subscriber
Uranus
Does any one know where I can find one? Looking for a control board for an MT2000. The model number of the MT2000 I have is H01RDH9AA7AN and its a MT2000 model III. The one I have has some pretty
bad corrosion and is causing the radio to not operate correctly .
I've tried cleaning the control board but still no luck... The radio will freeze and the display will fade out as if the battery was going dead, and I know for a fact that its not cause the same battery works fine on my MTS...
gary123
the MTSX series uses several different controller boards depending on the 'Flash options the unit was to support. what is the NTN number on the board?
In sme cases for a non trunked or lower featured unit you can re initialise a HT1000 board to work. Check out Batlabs for some info on this (the MTSX page)
62Truck
Ordinary Subscriber
Uranus
when my friend cleaned the board he took the sticker off with the NTN number on it...but seeing how this an MT200 and not an MTS and that the MT2000 isn't flashable I wouldn't think the NTN number would be of any importance I would think that just getting another controller board that came out of an MT2000 Model 3 with the same model number would work... and the board I have has pins connecting it to the RF board.
