MT2000 - how take out of scan mode ?
KG4INW
Midlothian, VA
If it's like the other Jedi radios (which I'm certain it is), scan on/off can be programmed to several different buttons depending on how it was setup. Or are you asking how to change scan settings in RSS?
thassler
Tennessee
When our MT2000's were in use, the scan on/off was usually programmed to the toggle switch on top of the radio.
RKG
Boston, MA
The RSS enables one to program "slaved scan" for any personality. If that feature is turned on, then scan is forced whenever that personality is "selected" and it cannot be turned off.
Jedi radio function depends entirely upon the programming of the codeplug in the radio. As a general matter, you won't get usable answers to questions like these unless the person you are asking reads the radio and analyzes the codeplug.
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
Well put.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Nothing to do with RSS, but thanks. I will have to call the programmer I guess.
Yes, it does. Functions like turning on/off scan on your type of radio are configured in the RSS and can be set to almost any button or switch, and the only way to know for sure is to read it into RSS (or CPS) and determine from there.
I normally use the concentric switch beneath the volume knob for scan on/off, because I don't need secure/clear. Others use the A/B/C switch. Others may use front keypad buttons or side buttons (I don't know if the Jedi can do it the same as the Waris (HT750/1250) as I've never tried it, but I've seen a Waris set up with one of the side buttons configured to toggle scan).
Devilz311
NJ
Like you said, call the person who programmed your radio if you don't have the software. If not, I'm sure you can figure it out eventually...
I've seen Jedi's with the any of the buttons set to scan. One of the popular configurations i've seen was assigned to the 3-way switch:
A- Scan
B- Blank
C- Scan list program - green button used to select scan members.
KG4INW
Midlothian, VA
Yes, or just try pushing buttons and flipping switches until the 'Z' annunciator disappears.
