MT2000 Top Button Problem
PTR-Jason
Silverpeak, NV
I have a UHF MT2000, top display 48 channel radio that I have a slight problem with.
When I programmed it, the top side button, blue/green button, even though it is unprogrammed turns on the green led and it stays on until it is pressed again, I do not know what it could be.
Even with the button programmed as the light button, it turns the display on as well as the led, light will time out, but led stays on. What could this be. Right now it is set to blank/ unprogrammed and still turns the led on when when pressed. It is the green led, not red, and it also makes a beep like an error beep.
I tried searching, maybe could not hit the right keyword, but any help would be grateful.
Thank you.
N4KVE
PALM BEACH, FLORIDA
All my radios do that. Even unprogrammed buttons. In the radio set up, there is a box to check where it says "any button pressed turns on light". If you uncheck this box, then only the light button will turn on the light. However as I reread the OP, it seems you have a bigger problem. The green LED should only come on when the radio is receiving a signal. The top side button is usually set to open the squelch on the radio. However try my 1st suggestion. Good luck. GARY N4KVE
