Mtotorla XTL5000 MDC1200 Key Up Mystery
portroyalbirdy
Central PA
#1
My brother has a XTL5000 in his truck that he uses for our local FD. Our Dispatch Channel and 3 Unit to Unit Channels use MDC1200. Everthing works flawlessly on the radio! We just have one mystery. On key up (PPTID), the wait tone works but has a short little burst at the end. Listen Here: ( https://drive.google.com/file/d/0BzJL8rYeMNAYRTNoYUE2YV84T1E/view?usp=sharing) my buddy is who does our programming is stumped too. Its still usable, but you just have to make sure you wait for the little burst. Thanks in advance!
#3
You have ptt sidetone enabled and using pre mdc id? Combined with clear tx tone? Disable ptt sidetone in your mdc settings or change it to short ptt side tone and or disable clear tx tone in the secure settings then try it.
