MTS 2000 Error Codes
drsalfen
Does anyone have the error codes for the MTS 2000? Assume they are generated from the RSS Software.
Specific interest is non-fatal Error Code: E09/10
Means scurenet is enable without an encryption board in the radio.
You can use the RSS to disable the securenet feature.
I have securenet option enable without an ecryption board in it and the radio works fine.
Keep it that way if you want the "beep" when you press the PTT.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
fineshot1 said:
The secure board must still be installed in the radio when using the rss to disable it otherwise the rss menu's will not allow it to be disabled.
I've never had a problem enabling or disabling the encryption hardware option without the board being installed.
The RSS option just tells the radio it has an encryption board. It does not check whether the board is actually there or not.
fineshot1
NJ USA (Republic of NJ)
You could be right. I always use the cps and thats how it works with cps. I should have specified that.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Not even the CPS cares.
The only time the radio communicates with the CPS (or RSS) is when a codeplug is read or written and it only checks to make sure that you're writing to the right model with the proper feature set.
fineshot1
Mike - I made the mistake of removing the secure boards in about a dozen MTS2000's and then got the above error. Only after re-installing the boards, reading the codeplug and unchecking the secure equipped check box & blowing the codeplug back in the radio did the error cease. I tried reprograming without re-installing the secure board and the cps had the checkbox grayed out so it was not possible to correct the problem, and I tried opening up the original codeplug and unchecking the box and blowing the codeplug in without the secure board but the cps protested about that also. Not sure why but thats the way it is.
drsalfen
Well after all of that. Since I will not be needing secure comm, and therefore the board, I'll just live with the error code as it appears to be meaningless for my use.
Thanks to all.
Dion
