MTS2000 CPS programming problem
RICHWILDER
Hi All,
Noob here trying to re-program an MTS 2000 Model II. I've changed some (49) of the conventional personalities, updated the Zone lists and tried to Write Device. The radio always comes back with "UNPROGRAMMED" after the download and "SELFTEST". When I save the codeplug file it saves without any invalid fields. Also, when I Write Device with the original codeplug file it works. Any help would be greatly appreciated! ;^)
Rich Wilder
Sparks, NV
bezking
On the Road
What's the radio's firmware version? Are you using the Windows-based CPS or the old text-based DOS RSS?
fineshot1
NJ USA (Republic of NJ)
Hi All,
Rich Wilder
Sparks, NV
Your thread title states"MCS2000 CPS programming problem" but then you go on to
say "trying to re-program an MTS 2000 Model II".
So please clarify what programing software you are using
and on what type of moto radio.
Mr_Observer
If the channel selector was selected to an unprogramed area of the Zone Channel Assignment when you had it on last then the radio will revert to UNPROGRAMMED. Crank the channel knob over to channel one and see if that helps.
RICHWILDER
Yes, it's MTS2000 CPS. And, yes, Mr. Observer nailed it! The radio came up in Zone 4 which has 1 channel programmed and the selector was set at 3. Rotated to 1 and it's now working!! Thanks to everybody that responded! ;^)
Rich Wilder
