MTS2000 error, how do I bypass this or write a new codeplug ?
KC2OVX
I have a bunch of old MTS2000 radios that I am trying to clear out the existing codeplugs and enter new frequencies and create new channels.
I have MTSX 6.08.00, and the models are
H01UCH6PW1BN
H01UCF6PW1BN
H01UCH4PW1BN
They all say the same thing when I try to read them, it goes through the blocks, some have 12, some have 24, some have 16, but they all read and reset and the software says:
Codeplug Too New For This Application
How can I bypass this ?
Or is there a way to clear the codeplug so the software will read a blank radio and allow me to write a new codeplug ?
How do I know what version of the software was used to write these ?
The ASK was removed, that I am sure of, so it is not an ASK problem.
Thanks in advance
Bill
KC2OVX
Easy way is to get a more recent version of the programming software. Should be fairly easy to find more recent versions on line.
Essentially what it is telling you is that the radio was written with newer software than what you have.
There is no reset that will clear that, you have to write a new codeplug.
KC2OVX
In reading posts, it looks like it needs R02.03.00 software ? Is this a CPS software that programs a lot of different Motorola radios or is it unique to the MTS2000 radio and only programs this model ? I guess the question is, is there other R02.03.00 that are for other radios, or if I find the R02.03.00 it will be the only one ? I see 2 other versions listed, both R01.03.00 and R01.13.00. Will these work if it was written with the R02.03.00. ? I seem to remember somewhere seeing a post that said if the radio was written with a newer version it gives a message that it is a newer version, but in some cases there is a way to get past that message and edit the codeplug. Am I thinking of something else, or is there a way to get past that message if I wind up using the R version cps that is older than what I have ? Is CPS a generic term or is it a specific program from Motorola that can program a lot of their models ? Thank you for the help. Hopefully once I get these programmed I won't have to mess with them again.
clbsquared
Isle of Wight County
You need R02.03. MTS CPS is specific to the MTS series radios. CPS stands for “Customer Programming Software”. It’s a generic term that Motorola uses for all of their software. But each series has its own specific CPS. Examples are:
CM series is Commercial CPS, CDM is Professional CPS, XTS/XTL is Astro 25 CPS, XPR/CM’d is MotoTRBO CPS, and APX is APX CPS.
I’m not aware of a hex edit for the MTS allowing the “rollback” to an earlier version. But there could be one.
It would be easier for you to find the latest version. It’s out there.
KC2OVX
Thank you for the information. I will keep looking. I don't know what version of CPS I found and if it is even for the MTS2000. Maybe one of my ham radio groups will have someone who has the latest version.
rescue161
KE4FHH
Hubert, NC
Whatever you do, do not use lab or depot software as you will ToolProof the MTS2000 if it has newer than version 5.42 firmware. There is no fixing that unless you saved an archive srecord.
Right, you need the "latest" CPS.
Sounds like you are looking at the wrong one if its showing a lot of different models. It's just MTS2000.
Should not be hard to find. I'm not in the office yet, or I'd pull it up and see what version I have on my old laptop.
rescue161
KE4FHH
Hubert, NC
I only mention the lab RSS as it will come up in your searches while looking for the latest CPS and if you don't know about ToolProofing, it will destroy your radio. Just a friendly reminder as it doesn't get talked about much anymore, since these radios fell out of use.
