Mts2000 FAIL 01/82 H01KDF9PW1BN VHF Code plug
big_baby
I need a good code plug for a MTS2000 VHF Model H01KDF9PW1BN System Package H35, Flash Code:000001-000000-9.
Read the codeplug changed it and wrote it back then got the dreaded FAIL 01/82 now nothing works. Ideas or suggestions?
gatekeep
FAIL 01/93
New York, NY
If you mean FAIL 01/93 yes your radio is bricked.
FAIL 01/82 is an external checksum error, check your RIB and cabling and, try writing the radio with the last saved codeplug FROM that radio in normal RSS.
If the firmware is greater then 5.41 DO NOT USE LAB RSS ON IT.
If you have a radio of the same model, type and flashcode, you can try to use normal RSS to clone the radio, if you don't have a saved codeplug from that radio. Do NOT confuse toolproof (FAIL 01/93) and external checksum error (FAIL 01/82) as the same thing.
MTS2000des
5B2_BEE00 Czar
If you don't have a saved codeplug for that radio, you may be out of luck. The depot still flat rates the MTS2000. A Fail 01/82 is an internal codeplug checksum error, you can sometimes clear it with a saved GOOD codeplug from that same radio.
More often than not, it's failing hardware in the controller. As others have said, DO NOT use LAB/DEPOT to WRITE to any MTS2000 with a F/W higher than 5.41 or you WILL have a paperweight for sure.
gatekeep
FAIL 01/93
New York, NY
Isn't the internal codeplug checksum error FAIL 01/92? I could have sworn FAIL 01/82 was external codeplug checksum error.
In either case MTS2000des is correct, it is also an indication of hardware failure.
MTS2000des
5B2_BEE00 Czar
you may be right, I haven't looked at the DSM for the Jedi's in a while.
Either way, throwing a codeplug from another radio in it isn't likely going to do anything.
These radios are showing their age, in my experience, the first 512K controllers were problematic. I suspect die bond delamination of the EEPROM IC's or OMPAC's causing the failure. I've had some luck by reheating with an appropriate heat focus head and revived a few radios.
With most of these approaching 15-20 years old, these problems aren't uncommon.
