MTS2000 Programming help
jtisdale656
Summerville, SC
#1
Hi, Can a Motorola MTS2000 (H01UCF6PW1BN) be programmed on a 800MHz SmartZone Trunking System to receive only? I have Motorola CPS software for MTS radios. I am kinda new to Motorola programming and only really messed with Kenwood programming so any help would be appreciated.
Mississauga Ontario
#2
What is the flash code
jtisdale656
Summerville, SC
#5
ok thank you. I've been trying to just set it up in general but I keep getting a error on the talk groups. I add a talk group and it turns red and won't accept it in the radio trunking configuration.
jtisdale656
Summerville, SC
#6
I've had no problems setting the conventional frequencies and trunking control channels but the talk groups is always coming in red as a error.... (if that helps). I've seen 1,000 videos about programming conventional just nothing about programming trunking.
lacoscannerguy
#7
I can't say for sure, but my guess is that is related to the lack of a system key. To program trunking systems, you need a key that allows you to do this; even if it's for monitoring purposes only.
jtisdale656
Summerville, SC
#9
I set up the system key through DOSBox. Everything is programming correctly except any talk group I try to add. It's on SmartZone type 2 throughout the entire configuration.
N4KVE- I'm not sure how to set it as Smart Net. I don't see a setting change for that from SmartZone.
jtisdale656
Summerville, SC
#10
As long as it shows the #1 under talk group in the talk group section of the Trunking Personality 1 of 1. Once you add a talk group it turns red and shows "Trunking Personality Talkgroup in Trunking Personality-1, member 1"
